Zetec thread size - Pressure sensor
Matt_C - 17/4/13 at 09:57 AM
Morning guys,
I was hoping somebody could help me with a tread size on the silvertop zetec block. I am adding a pressure sensor into the plugged hole to the left of the pressure switch as I intend on having both the switch and sensor wired in. As all the pressure sensors are 1/8 npt thread I also need to purchase a thread reducer but I am not quite sure of the size I need.
The image below is the hole I intend to use (with a bolt in), the bolt is M12 X 1.5 (a bit loose and the thread pitch is wrong). I am now confusing myself with imperial NPT thread sizes (which I am assuming is the thread type I need). It would make sense, with the plug I took out measuring 0.532", for it to be 1/2" but reading up on NPT threads a 1/2" has a OD of 0.84". So is this threaded hole actually 1/4"NPT the same as the hole the pressure switch is in?
Does this match the type of pressure sensors other people have used?
1/8 NPT OIL PRESSURE SENDER SENSOR for Autometer VDO Smiths Auto Gauge Dial | eBay
Viva la metric!
Paul Turner - 17/4/13 at 12:03 PM
No idea if the threaded hole adjacent to the standard oil pressure switch is the same thread but the Ford fit one in the photo is definitely 1/4 NPT.
I use a mechanical gauge on mine and an adjustable pressure switch with a 1/8 npt thread. I simply removed the standard Ford switch and fitted a
http://www.burtonpower.com/parts-by-category/ignition-electrical-instrumentation/gauge-accessories/oil-pressure-t-piece-1-4npt-pinto-xflow-cvh-lma011. html
which gave me a 1/8 npt and a 1/4 npt thread. Been using the same tee-piece on my x-flow and Zetec since 1989 with no problems.
[Edited on 17/4/13 by Paul Turner]
coozer - 17/4/13 at 12:30 PM
Theres an 1/8npt hole blanked in the head straight above, I used that for my oil pressure gauge.
You can see it here on the far right just above the inlet...
Matt_C - 17/4/13 at 03:09 PM
Thanks for the advice. I have ordered a T-piece connector so now don't need to worry about the other thread size.
