Here ya go, check out the piccies.
Steve has a few sets of these parts left, as he made up some spares. £35 gets you the tubes without the holes in the main one. If you want the 4 holes
machined into the main tube for the runners to go in, its £5 extra... you won't get the little holes for injector and vacuum bits as they might
be in the wrong place though. Oh, and the runners would be supplied slightly longer than seen in the pic, you just cut to length and weld in.
We might be able to start the engine soon then....
