Guys,
Does anyone know what the tread is on the fan temp sensor show in my picture. I want to fit a bolt and tap that out for my water temp gauge
sensor.
Ian
where the hell is it?! I feel like an ant in your engine bay
oh found it...
take it out and have a look, it won't explode It might be a 1/4 tapered thread or a straight one if there's a washer. B&Q have loads
of brass plugs and one will fit, I'd also use PTFE tape.
Probably 5/8 UNF unless it's tapered in which case probably 3/8 BSP.
Originally posted by Ian D
I want to fit a bolt and tap that out for my water temp gauge sensor.
That looks like a Zetec with the ally thermostat housing, it has two temp sensors in it one for the ECU the other for the temperature guage. I don't think you will find it's for the fan although that might be controlled by the ECU.
