Hi,
Could anyone advise / recommend a place in the Nottinghamshire / Derbyshire area that could manufacture a custom exhaust?
Needs to be 3 inch!! Most places I've tried seem to only do 2.5 inch as a maximum.
Thanks in advance...
Kevin
[Edited on 6/10/08 by archspeed]
Not quite in the area you specify but have you tried Custom Chrome in Nuneaton?
You could try Martin Keenan?
Thanks for the suggestions,
I've not tried Custom Chrome - It is a bit far (I'm assuming I'll have to take the car to them to get it measured / built, ) but having
said that I'll keep them in mind just in case, so Thanks for the suggestion..
Martin Keenan?? That name rings a bell - Was he somthing to do with MK Sportcars?? A quick "google" tells me his place is MK Engineering in
Rotherham - So it will definatley be worth a shout!! Thanks for that.
Keep em coming - this website is great !!
Yeah Martin used to own MK Sportscars before he sold it to his brothers (I think). His workshop is home based about 2-3 miles from MK's new place. He's a decent chap who from my experience has reasonable charges and is very knowledgeable in what he does.
Tony Law in Leeds.
Second to non in my opinion.
Tony Law does look good aswell!!
Wish I'd done this post last week, would have saved me no end of time !!
Thanks for the replies so far.....
Kevin
i had mine done by a guy in bilsthorpe notts link to my zorst
Originally posted by grazzledazzle
Tony Law in Leeds.
if your building a cosworth i assume you have a turbo ?
if so , its quite easy to build your own , i did mine .
Bends problem is easy, make em all from 90 deg bends, remember you don't have to use the whole bend!!!
Just a thin wedge from a 90 deg bend will get you a 7 deg one.
I thought Jetex made 3 inch silencers.
Failing that, milner offroad certainly sell the bits to make 3" silencers
PS for the bends, use stainless dairy piping and bends, they are dirt cheap, cheaper than demon tweeks mild steel bends by miles
Thanks for all those who replied, its given me plenty to think about!
Kevin
