Lightning
posted on 6/3/11 at 06:57 PM |
Middy oversteer
Just let my mate drive my car. He put it into a roundabout and spun it. I have noticed myself that it does rather dig into the corners. What could I
change to reduce the oversteer?
Just got the thing back on the road after modifying the exhaust. Now reads 95 dB at 7500revs....result.
MakeEverything
posted on 6/3/11 at 07:03 PM |
quote: What could I change to reduce the oversteer?
Ease off the throttle?
Kindest Regards,
Richard.
Lightning
posted on 6/3/11 at 07:05 PM |
Good point. but not what i had in mind
MakeEverything
posted on 6/3/11 at 07:09 PM |
Lol,
Have you looked at your camber on the rear? Suspension setup may be a little unforgiving. Try softening it up a bit.
Kindest Regards,
Richard.
tomgregory2000
posted on 6/3/11 at 07:11 PM |
Dont let anybody else drive your car
sorry no help, i guess its going to be a case of changing sping rates and damping and tracking, its going to take alot of time and money i fear
Lightning
posted on 6/3/11 at 07:15 PM |
He should have known better being on traffic. There is a fair bit of camber on the rear . It is adjustable could reduce it a see what happens.
whitestu
posted on 6/3/11 at 07:21 PM |
What toe are you running on the rear? Toe out will increase oversteer I think.
Stu
loggyboy
posted on 6/3/11 at 07:25 PM |
As you say its digging in, I take it its enduced by weight transfer under breaking/lift off rather than transfer backwards when accelerating out of a
bend?
Tyre pressures - more at front, less at rear
If you have single adjustable shocks - soften the rears, stiffen up the front end shocks (lessen the weight transfer to the front),
If you have double adjustbles then soften the rebound on the rears, stiffen the bounce on the fronts.
(PS this is based on computer game set up, so pinch of salt to be taken - LOL)
[Edited on 6/3/11 by loggyboy]
v8kid
posted on 6/3/11 at 07:39 PM |
Stiffer front antiroll bar or springs
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
RazMan
posted on 6/3/11 at 07:46 PM |
A slight adjustment to camber will make quite a difference. How is it set up at the moment?
I run about 1 degree front and 1.5 degrees rear - I can drift if I really try to hang the ar$e out but it is controllable.
Raz
MakeEverything
posted on 6/3/11 at 07:49 PM |
I would set it at "0" and see if that makes it any easier to drive. Then you can start making 0.5deg incremental changes.
Kindest Regards,
Richard.
Lightning
posted on 6/3/11 at 08:07 PM |
Thanks for your input guys.
I will try different things as suggested but one at a time and note the difference.
I'll try tyre pressures first as thats the easiest
procomp
posted on 31/3/11 at 07:45 PM |
Hi
Actual static camber settings are one thing. WHAT is happening to the camber during a corner / roll situation. You may find that it is heading in a
Positive direction and reducing the camber rather than pulling more negative camber on. You need to know the answer to this before making any logical
camber settings.
Cheers Matt
