jonbeedle
posted on 30/7/06 at 10:48 PM |
DISASTER....nearly!!!!
Well I've covered about 500 miles since the car was registered last Saturday and yesterday me and the missus decided to take the 'Tin
Lizzy' to the garden centre in Bury St Edmunds to pick up a couple of things, (any excuse for a blat!). Anyway after a pleasant poodle through
the back roads for a few miles we hit the A14, then it was pedal to metal straight into the outside lane up to about 70mph. Big cheesy grins all
around were replaced by worried looks as the engine started banging clanging, popping and banging some more We limped the next half a mile to the
next exit and into MFI car park. With no tools aboard, I remembered that a fellow Locostbuilder, matty_64's dad Simon, who had helped me out a
couple of times before, lived nearby and I had his number in my mobile. A quick call was all that was required for him to abandon his ironing and get
him along with some tools. He was there within 10 minutes with enough gear to carry out a full engine rebuild!
After removing the rocker cover we discovered that the rocker shaft had come loose and a couple of the bolts were almost all the way out.
We tightened the bolts to the correct torque (Simon had brought a torque wrench and knew off the top of his head the correct setting...naturally) and
within minutes all was well again!
I had a lucky escape. I could have sworn I checked those bolts when i torqued the head down after initially running the engine...but that was a year
ago.
. Anyway, massive thanks to Simon for coming to my rescue.
It just shows the power of this forum without which most of us wouldn't be on the road in our own creations and indulging in a fascinating hobby
and meeting great people.
Jon
"Everyone is entitled to an opinion however stupid!"
posted on 31/7/06 at 07:30 AM |
Sounds like Simon might be in-line for a couple of beers nice when things work out well!
David Jenkins
posted on 31/7/06 at 07:40 AM |
Come on Jon - you've only just got on the road! You don't want to go and break it already!
And how the hell did you manage to got through 500 miles in a week!
ned
posted on 31/7/06 at 08:28 AM |
this is what it's all about
beware, I've got yellow skin
SeaBass
posted on 31/7/06 at 09:51 AM |
I've learnt from experience that just about any bolt on a xflow can be rattled loose.
We had a very similar thing happen at a Trackday two years ago - the rocker post bolts loosened themselves. At first we whipped of the cover and I
reset the valve clearances but the noise got worse... Eventually someone peering over a shoulder said "Why is there a few mm of clearance under
that bolt head?". A couple of quick tightens and we were back on the track again.
I would have loved to see anyone in the many Skylines and EVOs even remove their rocker cover...
wicket
posted on 31/7/06 at 01:47 PM |
100 miles after getting on the road the engines coming out to re-fit the starter ring. A new ring was fitted during the build by a local company,
won't be using them again in a hurry!
posted on 31/7/06 at 05:10 PM |
I'ts a good idea to go over the car and check/tighten all nuts/bolts /screws etc even things you know you tightened when you built the car.Also
check cycle wing mountings for cracks etc . Guess how I know?
jonbeedle
posted on 31/7/06 at 06:42 PM |
Yeah but....You know how it is! Too busy having fun!
That's sound advice though.
See some of you at the weekend. Looking forward to it.
Ciao!
