graememk
posted on 19/5/07 at 06:54 PM |
1st break down today
not bad i've covered 900miles since my sva, on the way to spalding tonight there was a big cloud of steam from the bonnet. nothing to bad just a
hose come off, bit of a bugger though as i lost my water wetter.
luck i had some water and tools with me, just didnt get time to use the £10 worth of juice i had just put in
speedyxjs
posted on 19/5/07 at 07:59 PM |
Bad luck but at least its nothing serious
ASH3
posted on 19/5/07 at 08:13 PM |
Only your first!!
He He get used to it...
but it just gets better and better
Dont call me out though
graememk
posted on 19/5/07 at 08:26 PM |
quote: Originally posted by ASH3
Only your first!!
dont call you out ??? but your the head of the MK owners club, your number one voice dial on my phone
whitestu
posted on 19/5/07 at 09:33 PM |
That's the only thing that has caused me a problems so far - i.e. a hose coming off.
I used some domestic high temp plastic water pipe in my cooling system. Not sure if it went a bit soft or was too short [I'm still talking about
my cooling system].
The longer piece I replaced it with has been OK so far.
I'm thinking I should replace with some Ali pipe.
What do you think?
Stu
caber
posted on 19/5/07 at 11:58 PM |
At least copper plumbing pipe! plastic is temperature rated for liquid running through it not radiant heat from exhausts or contact heat from touching
or being fixed to hot bits! I f you like the copper look polish it if not spray black, no one need ever know it isn't expensive ally pipe that
has been powder coated
Caber
RazMan
posted on 20/5/07 at 12:53 AM |
In 3500 miles since SVA I have run out of petrol ....... and I never want to do THAT again
Raz
posted on 20/5/07 at 07:23 AM |
Broke down on the way to SVA , carb had iced up but then so had I. No problems with carb since
