Author: Subject: pulling right under acceleration
rodgling
posted on 6/5/11 at 02:56 PM Reply With Quote
I assume this is due to not yet having a proper geo setup (this is very high on the list of things to do, obviously). I've done ride height and front toe & camber but not done the rear other than "roughly parallel by eye".
Currently it drives well, but under acceleration when the rears are spinning, it pulls hard to the left (back swings out to the right).
What should I be looking at to address this? Rear toe (I assume a bit of toe in is what I'm looking for)? Could it just be the way the LSD distributes power between the wheels?
Ben_Copeland
posted on 6/5/11 at 03:08 PM Reply With Quote
Dont spin the wheels. It's going to go all over the place if there's no grip on the rear wheels
Ben
Locost Map on Google Maps
Enter Your Details Here
Bluemoon
posted on 6/5/11 at 03:34 PM Reply With Quote
Quite.. You will find the nearest lamp post.. You should get the geometry set up though, string box for me seems to have worked o.k not sure but there must be a few threads on here on a DIY setup?
40inches
posted on 6/5/11 at 04:00 PM Reply With Quote
What are your tire pressures?
rodgling
posted on 6/5/11 at 08:36 PM Reply With Quote
True. It is fun though. (I was careful to do it in a wide, empty bit of road). Most of the time I'll have traction control to help deal with this sort of thing, I just had it turned off for giggles.
I'll get the geo set up and see how it goes.
Ninehigh
posted on 21/5/11 at 09:04 PM Reply With Quote
Isn't this something to do with the rotation of the propshaft/engine under hard acceleration, where giving it the boot twists the chassis and (I'm guessing) would cause uneven traction?
Neville Jones
posted on 23/5/11 at 10:03 AM Reply With Quote
Probably due to more weight on RH back wheel under acceleration, giving that wheel more bite/less slip.
But, if your setup is anything like some of the big name cars I've seen, the wheels could be pointing anywhere.
Nev.
posted on 23/5/11 at 10:26 AM Reply With Quote
On an IRS car you need to get the toe-in and alignment of the rear set properly (a rear wheel should never toe-out) and the corner weights set with the car loaded as it normally driven.
