<<  1    2  >>
Author: Subject: 40...50...60..70..then slip and slide!??
cryoman1965
posted on 21/8/06 at 03:44 PM Reply With Quote
Hi Chaz, my car does exactly the same as yours. Worst car i have ever driven. Found this post by snoopy but not tried it yet.
basic setup
tracking 0-1degree toe out
camber 1 degree in all round
caster mushroom inserts offset hole to front
tyre pressures 17 -18 p.s.i
damper settings around 7 clicks
ride height personaly about 4 inch
Will try this myself when i return from Hols.
Cheers Nige.
procomp
posted on 22/8/06 at 07:09 AM Reply With Quote
HI yes if the trailing arms on a live axle setup are to far of parralel that will also cause some rear steering problems. Witch means that cars such as the mk and luego need to run at about 5-6" ride hight at the rear .
cheers matt
posted on 22/8/06 at 09:17 AM Reply With Quote
It's an Indy (independent) so it's the rear wishbones in permanent droop by the sound of it.
Do you mean not parallel to the ground for the live axle trailing arms?, they must be parallel to each other to work or they will lock.
procomp
posted on 22/8/06 at 10:16 AM Reply With Quote
Hi for your average road going locost the arms parralel to the ground and each other will do. But if you want to take advantage of the fact that you have a live axle then no all i will say is do some research on mallock clubmans. If you can get the geo right then it's amazing what you can get the car to do. Get it wrong and the car has no grip and rear steers like a pig.
cheers matt
procomp
posted on 22/8/06 at 01:33 PM Reply With Quote
Hi rear ride hight is ussually messured just in front of the rear wheels.
cheers matt
Scubastu
posted on 22/8/06 at 08:20 PM Reply With Quote
A mate of mine has an MK Indy with the same 'wandering' problem.
He asks what tyres are you running?
He has 195/60/14 Yokohama A048's.
procomp
posted on 23/8/06 at 07:13 AM Reply With Quote
Hi would be worth try the 4" rh to see if the change in geometry has any benificial effect on the front. the rear needs to be level or up to 1/4" higher at the rear but all this will only work if you have the right amount of travell on the shocks ie not hitting the bumpstops or topping out . And don't forget that if you move the rh more than 4-5mm you will need to readjust the camber and tracking.
cheers matt
edit to say remember that all rh camber and tracking should be done with you or replacement weight onboard.
[Edited on 23/8/06 by procomp]
NS Dev
posted on 23/8/06 at 05:17 PM Reply With Quote
Are you sure that the lower rear wishbone slopes upwards from chassis end to wheel end when the car is at normal ride height?
If so then it sounds like an issue!
Rule of thumb is as follows:
Really the wishbones should move a roughly equal amount "above" and "below" horizontal in bump and droop.
They should also be somewhat divergent from the chassis end to the wheel end, and obviously the top wishbone will tend to need to be somewhat shorter than the lower one in order to pull on negative camber in roll.
The fact that they are divergent obviously means that the amount of movement of the upper and lower wishbones is not strictly equal above and below horizontal but you see the point I am making hopefully!
If all that is happening then the car should drive ok to a greater or lesser extent.
BKLOCO
posted on 26/8/06 at 05:48 PM Reply With Quote
Originally posted by David Jenkins
I am also surprised that manufacturers haven't sorted this yet (and it's not just MK). ........
There's no argument as far as I'm concerned - don't do a bodge to get through the SVA - fix the problem.
GTS have fixed the problem. (as have some other manufacturers)
The GTS bones/chassis set up has 7 1/2 deg caster and self centres perfectly without resorting to the MK bodge.
blitzmk2
posted on 2/11/06 at 02:36 PM Reply With Quote
Front Geometry
Has anyone got a drawing for the correct wishbones, so I can make some. I am new to the site, will you need my E mail address?
<<  1    2  >>
