posted on 21/12/08 at 10:37 AM |
Pride goeth before a...
...flying bonnet!
I think it was just a week or two ago when I declared that the one thing I check before taking the car out it that the bonnet's properly
fastened...
...did you know that when you accelerate hard, and reach about 65 - 70mph, that an unfastened bonnet will fly into the air and land in the fast lane?
Fortunately a passing cyclist ran into the road and grabbed it before it got run over (he has my eternal thanks!) and, just as fortunately, it landed
flat on its underside. The only damage is one small bend in a corner.
Phew!
DIY Si
posted on 21/12/08 at 10:41 AM |
That was bloody lucky! Did you try and catch it as it went over your head?!
Sun Tzu, The Art of War
posted on 21/12/08 at 10:45 AM |
No! I was in the "what the hell was that?" mode at the time...
speedyxjs
posted on 21/12/08 at 10:52 AM |
Thats was very lucky
omega0684
posted on 21/12/08 at 10:58 AM |
ive read a few posts now about people who forget to fasten their bonnets before going out. thanks god that it wasn't GRP otherwise it might have
shattered in the road as it landed.
on the other hand surely its the last thing you do before you get in the car to drive away. i always start the car with the bonnet off, and allow the
car to warm up for 5-10 minutes before putting the bonnet back on and then getting in the car!
pinto
posted on 21/12/08 at 11:12 AM |
No the feeling
same happened to me in the tiger
so a fibreglass bonnet went flying over my head at about 70+ mph landed in middle lane with cars going every were
luckily one stopped and protected it while i embarrassedly went and retrieved it only about same damage as yours some how
its a bit worrying for the next few times out
Wadders
posted on 21/12/08 at 11:29 AM |
I think most 7 owners try this entertaining trick at some point
Popped my cherry at Donny, just before craner curves, the bloke in the elise behind me looked like this
Al.
posted on 21/12/08 at 11:30 AM |
That's the good thing about Dzuz fasteners (as long as you remember to "close" them). The chance of them coming undone is pretty
small....
mistergrumpy
posted on 21/12/08 at 11:36 AM |
So the cheese on toast theory goes out of the window then and faith in society is redeemed again as a cyclist picked it up for you.
I remember losing the peak off my cycling helmet once and every sod went out of their way to run over it with their cars
posted on 21/12/08 at 11:53 AM |
its very dangerous really, when you think about it. The chance of getting twatted in the face, or someone swerving and causing an accident. Surely
there must be some way to reduce the risk of it happening? A one piece bonnet and nose is the one that springs to mind, hinged at the front.
posted on 21/12/08 at 12:02 PM |
Westfields have the nicest solution - two pegs in the front that locate in the nose, and 2 locks at the back. Even if you forget to lock the back,
the bonnet's going to flap around a bit before flying - at least you'll get a warning and a chance to stop before it goes.
I was wondering about some automatic latch like you get on car bonnets - the type where you have to reach under to undo it.
Alternatively, some form of microswitch to let you know that it's not fully down and latched.
Or, as I should have done, have a quick look along the side of the bonnet before I climb in!
iscmatt
posted on 21/12/08 at 12:44 PM |
There were too many horror stories for my liking and when heading back from SVA on the motorway to see the bonnet lifting at the front is a scary
sight, luckily on that occasion i got onto the hard should and zip-tied each latch together, when i got home i bought 4 of these (2 sets of 2) from
ebay.
Look quite good too, though only for AFTER SVA
iscmatt
posted on 21/12/08 at 12:47 PM |
mind you the above doesn't avoid you forgetting to secure them, they are just much stronger and capable of dealing with vibration that i fear
the rubber SVA compliant ones are not. All in my own experience of course
posted on 21/12/08 at 01:06 PM |
I had one of those cunning plans as I wandered down to the pub this lunchtime...
How about a couple of pegs bonded to the bonnet, poking forward under the lip of the nose cone. At the back of the bonnet there could be some form of
latch to fasten to the scuttle (this may not be necessary). Even if you forget to fasten the bonnet clips, it will only rattle around until you stop
and fix it properly. To remove the bonnet, all you'd need to do is to undo the latches, lift the back end of the bonnet, then remove up and
backwards.
[Edited on 21/12/08 by David Jenkins]
Bigheppy
posted on 21/12/08 at 01:15 PM |
STOP PRESS
new rule added to IVA, bonnet secure light must be visible while the engine is running
Danozeman
posted on 21/12/08 at 02:58 PM |
you were bloody lucky david!! There doesnt seem to be much traffic about ipswich and the like today!!
Dan
DaveFJ
posted on 21/12/08 at 04:33 PM |
found the front of my bonnet shaking a bit frighteningly coming back from SVA.
As a few have seen on here I now have 2 large pins that stick out of the front and locate in 2 holes ......
front is really secure and 2 rubber type over centre catches seem to hole the rear well
I was worried about loosing the bonnet so was toying with the idea of a central catch at the rear with a remote release....
Dave
roadrunner
posted on 21/12/08 at 08:27 PM |
Glad to see cyclists can be helpfull as i am one and would glady help anyone in distress,on the other hand not many drivers seem to like or want to
help me.
speedyxjs
posted on 22/12/08 at 07:59 AM |
Thats what im planning to do. Too many horror stories on here.
I really hope you are joking. How much of a distraction would that be
posted on 22/12/08 at 01:17 PM |
Would be useful if you invert the logic - light shining if the bonnet ISN'T closed properly.
