norfolkluego
posted on 21/11/09 at 04:05 PM |
Zetec manifold studs
Anyone know the size, I need a new set?
(1.8 blacktop if that makes any difference)
deezee
posted on 21/11/09 at 05:11 PM |
Inlet or Exhaust? You can get M8 exhaust ones off ebay / Burton Power for £1.50 each. Complete sets are listed on Burton... but they ain't
cheap!
norfolkluego
posted on 21/11/09 at 06:20 PM |
I need a full set of both, didn't realise they were that expensive!
will121
posted on 21/11/09 at 06:54 PM |
they are expensive ive been looking recently, but only needed two so not to bad, did wonder price of genuine ones. what i was thinking though why cant
you use basic 8mm studs from some where like beardshaws in Rackheath (dont know if be any cheeper though) and
locktight them in?
norfolkluego
posted on 21/11/09 at 07:15 PM |
If it's bog standard M8 why can't you just cut some M8 bar to length (this must be a daft question)
will121
posted on 21/11/09 at 07:35 PM |
technically cant see why not, only thing i can think of what would be different is threaded rod would tighten up on bottom thread in hole rather than
shank bit, but if lock tighted in would think ok?
stuart_g
posted on 21/11/09 at 10:10 PM |
For the inlet manifold wht not just use M8 bolts?
Ian D
posted on 22/11/09 at 10:56 AM |
Ive used M8 bolts for both inlet and exhaust. in fact the ford inlet does use bolts.
norfolkluego
posted on 22/11/09 at 01:37 PM |
Cheers everyone, you've just saved me <count..count..count..count..count> quite a lot
norfolkluego
