Author: Subject: anyone work with ally for dash project?
daniel mason
posted on 7/7/10 at 10:26 PM Reply With Quote
is anyone on here able to work and cut ally for mounting clocks and switches?
i ideally want something 8-10 mm thick as long as can pass the radius test, it will be rectangular in shape but will have a semi circular cut out for clocks and 3 small rectangles for swtches
designer
posted on 8/7/10 at 06:20 AM Reply With Quote
I would have thought any laser cutting place could do it for you.
ali f27
posted on 8/7/10 at 07:20 AM Reply With Quote
purdy would do it mj engineering currently building mk for customer
MakeEverything
posted on 8/7/10 at 07:42 AM Reply With Quote
A 10mm thick ali dash???
Kindest Regards,
Richard.
posted on 8/7/10 at 07:55 AM Reply With Quote
Make it in 3mm, or thinner if you can brace it behind.
A good engineering shop should be able to roll a 19mm radius on the bottom for you.
posted on 8/7/10 at 08:06 AM Reply With Quote
Daniel - do we understand right that you want to make an entire 1 piece dash out of 10mm thick ally?
That will cost a rather large wad to get the material alone, never mind getting it machined, finished (anodised) and fitted.
...or do you mean an insert panel to fit into/behind a GRP/Carbon dash panel?
posted on 8/7/10 at 09:18 AM Reply With Quote
I don't think the entire dash is going to be made from 10mm ali sounds like a little centre console type thang....
boggle
posted on 8/7/10 at 10:41 AM Reply With Quote
i made my ali dash from 3mm.....
10mm is mahooosive!!!
u2u me for details
supercat
posted on 8/7/10 at 11:30 AM Reply With Quote
Me too. 3mm with a small brace behind the switch area. 10mm is a bit extreme
daniel mason
posted on 8/7/10 at 05:54 PM Reply With Quote
just a small rectangular section with a cut out for my clocks. will 3mm be sturdy enough?
posted on 9/7/10 at 09:12 PM Reply With Quote
Ample and much easier to get hold and work with. Water jet or laser profiling would be an easy job, but it really wouldn't be hard to do manually with hole saws/files etc.
