PuppiesBalls
posted on 16/7/10 at 10:19 PM |
I Need one of these for my sierra drive shafts
Does anybody have one of these lying around?
Its the little part which the drive shaft bolt goes through
ReMan
posted on 16/7/10 at 10:37 PM |
Ahah, the ballast weights, added instead of casting the diff body out of iron
PuppiesBalls
posted on 16/7/10 at 10:53 PM |
What do u mean dude? These are the little plates that are like 50mm long and thers 3 of them at each end of the drive shaft
mark chandler
posted on 17/7/10 at 07:24 AM |
Throw away and use shakeproof washers if you have ruined one
ReMan
posted on 17/7/10 at 08:41 AM |
Sorry for the humor, I don't see what is so special about them?
If the had locking tabs on them they would be useful, but as they are \I can only see they are glorified (heavy) washers
plantman
posted on 17/7/10 at 04:19 PM |
i used thse http://www.namrick.co.uk/acatalog/Home_Mixed_Plain__Spring_and_Shakeproof_Washer_43.htmlesw
as above
[Edited on 17/7/10 by plantman]
supercat
posted on 17/7/10 at 06:29 PM |
I replaced mine with shakeproof (split) washers, much more effective at holding the bolts tight!
PuppiesBalls
posted on 17/7/10 at 09:06 PM |
Any body got one?
Xtreme Kermit
posted on 17/7/10 at 09:55 PM |
Nope - I bought a new set of these from ford when I replaced the back end on mine.
not cheap though...
bob
posted on 17/7/10 at 09:59 PM |
I think i may well have some, i will have a check in the morning before i go to the uxbridge show.
