Author: Subject: OT: north - south M1 - A1/M18?
vinny1275
posted on 1/9/10 at 08:21 AM Reply With Quote
Morning all,
A bit of an off-topic question really... I'm driving up to Newcastle and back a fair bit at the moment, and I'm wondering which route's quicker - M1, or M18 / A1? My experience so far is that the A1's straighter, but as it's only 2 lanes you're more likely to get stuck behind trucks for long stretches at a time...
Anyone know if one's better than the other?
Vince
fha772
posted on 1/9/10 at 08:31 AM Reply With Quote
Hi Vinny,
TBH, it's a case of, 6 or 2 3's, the A1/M18 route is shorter and quicker, unless you get a hold up, then like you said, it's a nightmare.
I would take the safer route, of the M1/A1, but if your travelling in the "off-peak" times, then i would take the M18/A1.
So, it's really down to, the times of day you travel.
http://www.ppcmag.co.uk/forum/viewtopic.php?f=47&t=6743&start=105
whitestu
posted on 1/9/10 at 09:00 AM Reply With Quote
That's a rotten drive at the moment whichever way you go.
Is staying at home an option?
r1_pete
posted on 1/9/10 at 09:07 AM Reply With Quote
Either way has its ups and downs, I live close on M1 J31, the one before the M18, and generally find the A1 slightly quicker, and less frustrating, and little more picturesque (if you can call it that) but there isn't much in it.
GMPMotorsport
posted on 1/9/10 at 11:31 AM Reply With Quote
one thing for sure which ever one you pick the other one will be quicker, a bit like the ques for the checkout in the supermarket!
www.gmpdevelopments.co.uk
www.gmpmotorsport.co.uk
ARDS Instructer.
40inches
posted on 1/9/10 at 11:53 AM Reply With Quote
I use the M1/A1, the M18/A1 seams to suffer if the traffic gets heavy, more so than the M1/A1.
vinny1275
posted on 1/9/10 at 12:44 PM Reply With Quote
Thanks guys, as I'll be getting to Newcastle abotu 9-ish in the morning, I reckon the M1 might be a bit more free. I'll give it a go tomorrow morning when I go up....
vince
Davey D
posted on 1/9/10 at 05:46 PM Reply With Quote
You can always take the A19 instead of the A1 north
Davey D
posted on 1/9/10 at 05:48 PM Reply With Quote
Guinness
posted on 1/9/10 at 05:55 PM Reply With Quote
I reckon Swindon to Newcastle to be about a 5 hr drive. I'd be going north up the A34 to Oxford, M40 to the Stoneleigh turn, round the bottom of Coventry, up the M69 to Leicester, then M1 to Sheff, M18 towards Donny, then A1M home.
(I used to live in Salisbury, so I've done this route dozens of times).
However, there is a major section of 50mph limit between Dishforth and Leeming at the moment, which will slow you down, but no more than being stuck on the A19 round the 'boro in rush hour.
If you are coming up this weekend, bear in mind that the A1 is going to be shut for these roadworks
If you are going to be coming up regularly, I'd be tempted to fly, or at least train it (unless you need to bring loads of gear with you).
If you have to drive, I'd consider coming up the night before (8pm-1am) as it'll be loads quieter.
Mike
