Author: Subject: Video's from bedford track evening yesterday
locoR1
posted on 4/9/10 at 08:01 PM Reply With Quote
Had a brilliant time yesterday with afj (Alan) and madteg (Kev) blasting round Bedford Autodrome, after all the rain we've had we were all praying for good weather looks like it worked! glorious sunshine all day
This is the first video got two more uploading so will post them when they are done (probably tomorrow now)
1st VIDEO
Dave...
[Edited on 4/9/10 by locoR1]
Check out my CB500T Cafe Racer build diary
john77cars
posted on 4/9/10 at 08:27 PM Reply With Quote
good video,can you tell me what camera you are using and mount,mine keeps wobbleing.
PAUL FISHER
posted on 4/9/10 at 08:32 PM Reply With Quote
Sounds great, looks like you could have done with another gear down the back straight though.
locoR1
posted on 4/9/10 at 09:48 PM Reply With Quote
Its a 420 line bullet cam recording onto a DVR from China, it messed me about a bit so wouldn't recommend it.
Paul, could really do with a 3.14 (3.38 lsd fitted) that back straight seems to go on for ever, i was just backing of at about 110 instead of risking the engine, would be on the limiter half way down if i didn't.
Second video is uploaded, This is me taking Alan (afj) for a few laps, had brain fade on the first lap and braked way way to late
2nd VIDEO
Dangle_kt
posted on 5/9/10 at 10:14 AM Reply With Quote
Nice video!
what was the green seven you were chasing?
Seemed as quick as your turbo r1.
afj
posted on 5/9/10 at 10:20 AM Reply With Quote
passinger ride with locor1 = brown pants was fun being scared half to death
eerrrrrrrrrrrrrrrr
eddie99
posted on 5/9/10 at 11:20 AM Reply With Quote
Originally posted by Dangle_kt
Nice video!
Green seven i'd assume was madteg's turbo zetec
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
locoR1
posted on 5/9/10 at 12:19 PM Reply With Quote
Nice video!
Yup was madteg not allot in it between us think ive got him on handling probably that big heavy engine!
Alan pull you finger out and get you video up! same to Kev i want to see my spins from your car
madteg
posted on 5/9/10 at 02:05 PM Reply With Quote
Not got a lead from mp3 to laptop, will go to maplins now.
afj
posted on 5/9/10 at 03:16 PM Reply With Quote
my video is on you tube now but rubbish wind noise and poor picture dont know how to link it but search for bedford track day 003
eerrrrrrrrrrrrrrrr
locoR1
posted on 5/9/10 at 04:42 PM Reply With Quote
Picture looks quite good shame about the wind noise, would be worth taking it apart and seeing if its possible to remove the microphone, then put it on a cable.
LINK to Alans VIDEO
afj
posted on 5/9/10 at 06:17 PM Reply With Quote
thanks dave
eerrrrrrrrrrrrrrrr
bigfoot4616
posted on 5/9/10 at 06:29 PM Reply With Quote
good video's. how do you do with the noise at bedford, thought they where quite strict on it.
also how is your bullet cam mounted? mine wobbles a lot a high speed
locoR1
posted on 5/9/10 at 06:51 PM Reply With Quote
Mine just got through the static test limit was 101db mine was 100.7db but that's mainly due to it not running clean off boost, i did short shift past the drive by noise meters till near the end but it wasn't a problem flat out but my car is very quite being turbocharged.
Bullet cam is mounted using a jubilee clip with a brake connection welded to it tapped for a 6mm bolt see picture below
Bullet cam and mount
bigfoot4616
posted on 5/9/10 at 07:36 PM Reply With Quote
that mount looks interesting, will have to try something like that.
mine is an exhaust clamp with an alloy ring bolted to it which clamps the bullet cam. everything is bolted up solid to a point where i can't move it without a lot of force.
maybe it's to solid and wobbling due to vibrations that are being absorbed by your mount
