Author: Subject: r888s vs slick tyres
john77cars
posted on 19/9/10 at 09:10 PM Reply With Quote
im running r888s for trackdays and thinking of getting some slicks,will i notice a diffrence with slick tyres on compered too the r888s.
posted on 19/9/10 at 09:16 PM Reply With Quote
Oh yes!
It's Evolution Baby!
Dangle_kt
posted on 19/9/10 at 09:17 PM Reply With Quote
especially in the wet
locoR1
posted on 19/9/10 at 09:20 PM Reply With Quote
Check out my CB500T Cafe Racer build diary
matt_gsxr
posted on 19/9/10 at 09:23 PM Reply With Quote
Do you need to change the geometry for slicks? I only say this because I was running ACB10's which are crossply and need different set-up. I sort of thought that slicks might be crossply, but I don't really know.
It is a pain if you want to use radials on the roads, and slicks on the track as you don't want to be continually changing the geometry.
Matt
CNHSS1
posted on 19/9/10 at 09:50 PM Reply With Quote
just run crossply slicks with the ACB10s as the carcass construction is the same, identical infact, hence no issues with geometry changes.
Generally the difference between crossply and radial slicks, is that crossplies need near zero camber and toe and are more progressive near the limit of adhesion (they let you know ) and radials have a slightly higher ultimate limit but when they are gone, they are gone! Radials also benfit from camber.
As for 888s vs slicks, night and day, similar to Ditchfinder 3000s vs 888s....
Andy D
posted on 20/9/10 at 02:57 PM Reply With Quote
I would think new slicks are a fair bit grippier than 888s, but I've found there's not much difference between used Michelin (radial) slicks and new 888s.
The main difference is the price , second hand slicks at £15 a go, and 888s ... a bit more!
vyperstrype
posted on 20/9/10 at 03:14 PM Reply With Quote
Slicks Every time
Where there's a will, there's a death!!
Dopdog
posted on 20/9/10 at 03:26 PM Reply With Quote
but do poeple let you use them on track days?
Andy D
posted on 20/9/10 at 03:44 PM Reply With Quote
I've never had a problem, but I've heard of some organisers insisting that the car has suitable roll over protection.
Andy D
Dopdog
posted on 20/9/10 at 05:06 PM Reply With Quote
Got that then will have to look into this one
snakebelly
posted on 20/9/10 at 05:24 PM Reply With Quote
also bear in mind that slicks will need bringing up to temp before you get the best of them, also how you store them in between track days can affect their life. Some slicks are also only any good for a number of heat cycles.
Andy D
posted on 20/9/10 at 05:34 PM Reply With Quote
That's what I mean... the reason the racing teams get rid of them is because they're past their best. Still OK for trackdays though.
john77cars
posted on 20/9/10 at 06:47 PM Reply With Quote
thanks for the replys,im going too order some used michilin slicks and see how they are.
