locoboy
posted on 9/6/04 at 06:23 PM |
paintshop pro question
hi fellas,
im just back today from Chamonix Mont-Blanc and took loads of photos with my digital camera.
I took about 6 sequential photos of a mountain range and now i eant to put them all together to give a panoramic picture.
How do i do it! been faffing about for about an hour and cant seem to get it to work
Locoboy
Mark Allanson
posted on 9/6/04 at 06:27 PM |
Casio do a program called spinorama, you can join jpegs and it makes them into a quicktime movie (if you take enough shots you can do a 360)
Alan B
posted on 9/6/04 at 06:58 PM |
Col, you need to create a new blank image to cut and paste the others into...
Obviously, the new image will be much wider...![](/images//smilies/bigsmile.gif)
locoboy
posted on 9/6/04 at 08:08 PM |
i have gone
File>New (made it a much longer area), selected my file i want to cut and pase and done "cut" but when i right clic on my new document
to "paste" there is no option to do so.
Also i tried "edit" and the option for "paste" leads me on to a sub menue with >as new image, > as new selection> as
new layer etc but they are all greyed out ie not available, arrrrghhhhh!
i also tried importing the pictures via File > Import and i get all sorts of options " Scree capture" "twain"
"Digital camera" "Plug in import", the digital camera option doesnt do anything either.
f'ing technology!
Locoboy
Alan B
posted on 9/6/04 at 08:25 PM |
Rather than cut and paste do a copy and paste....but before that do ctrl-A to select it all first...then ctrl-c....then click the other(new image) and
go ctrl-L (new layer)
That "should" work.....
Staple balls
posted on 9/6/04 at 08:46 PM |
i've not used PSP in years now, but if you continue to have probs, i'll stick them together in photoshop
jmbillings
posted on 9/6/04 at 09:07 PM |
quote: Originally posted by colmaccoll
i have gone
When you say you selected the file you want to cut and paste, it almost sounds like you did the file in explorer? All you should need to do is make
your new image as you did, then for each source image do the following: open it in psp, go to edit, choose copy. Click on your bank image, do edit,
paste, new selection. The source image should appear as a floating selection which you can drag to where you want. Go to selections, select none.
Repeat for the others, should do the job!
Noodle
posted on 9/6/04 at 09:19 PM |
I've got a bundled program that came with my digicam - Canon Photostitch. I've used it a few times for landscapes.
If you think it might be useful, drop me a line.
Neil.
Your sort make me sick
locoboy
posted on 10/6/04 at 11:23 AM |
thanks for all the advice guys and the offers of help, i have managed to do it through trial and error and it looks quite impressive too.
Thanks again
Col
Locoboy
