jimgiblett
posted on 28/9/10 at 06:59 PM |
Cellulose based paints on POR15
Anyone know if I will have a problem spraying over it, I can't find much info on POR15. I am happy to spray an etch primer on first. POR sell
there own etch primer but it is nearly £20 for a rattle can
I ask this as I know hammerite is a pain as it is silicon based.
Jim
marcjagman
posted on 28/9/10 at 07:11 PM |
Filler primer then flat down, celly paint does sink a bit.
Mark Allanson
posted on 28/9/10 at 07:14 PM |
Because solvents tend to be much milder these days, cellulose will pickle up almost anything you paint over these days - you shouldn't really be
able to obtain it as its sale is 'illegal'
Paints are designed as systems so you should use whatever is recommended by whoever manufactures POR15.
marcjagman
posted on 28/9/10 at 07:20 PM |
Nearly every car paint supplier I know will happily sell you celly paint, not illegal till 2014, just being phased out.
posted on 28/9/10 at 07:54 PM |
I buy cellulose from local car spares shop and have no trouble obtaining it. It has a sticker on the can stating mixed paint to be used to paint a new
vehicle or other parts. It's just a get around to still supply it to the general public as they never actually ask what you are going to use it
on. I've not had any reaction problems with anything I use it on if it's been on there long enough to harden.
Mark Allanson
posted on 28/9/10 at 08:18 PM |
Has anyone here put celly over synthetic?
iank
posted on 28/9/10 at 08:22 PM |
There is a tie-coat in the POR15 range, but unfortunately it doesn't support cellulose.
I'd call frost and ask them if it's feasible.
http://www.frost.co.uk/item_Detail.asp?productID=8188&frostProductName=POR15%20Tie%20Coat%20Primer%20(946ml)
Edit2:
Forget Frost email support@por15.com
There is lots of information on POR15 on their website unfortunately celly topcoats isn't there (or I didn't see it).
[Edited on 28/9/10 by iank]
Anonymous
Mark Allanson
posted on 28/9/10 at 08:26 PM |
...........but unfortunately it doesn't support cellulose........
I cannot think why
jimgiblett
posted on 28/9/10 at 09:34 PM |
hmmm I'll call Frosts. I have a tin of POR15 but didn't want to use it if I have to scrape it all off later.
Jim
BillHoll
posted on 29/9/10 at 07:19 AM |
If you are worried about the compatibilty of any paint your paint supplier can supply isolating primer which providing you do not break through the
coat when rubbing down will allow you to use cellulose over anything.![](/images//smilies/smile.gif)
jimgiblett
posted on 29/9/10 at 12:17 PM |
Will the primer stay attached to the POR15 though?
- Jim
BillHoll
posted on 29/9/10 at 01:56 PM |
Yes it sticks to anything, but to check the product is called Barcoat made by Upol. There is a data sheet available on the internet.
BillHoll
