Dangle_kt
| posted on 10/1/11 at 11:23 PM |
Winter drive out
Drove car home from old house. Cold, raining. Expected horrible time, but apart from lots of wheel spin it was actually fine.
The worst thing was the glare off my savage switches making the dark lanes a little tricky. Anyone else find this?
I think I'll do it more often!
RazMan
| posted on 10/1/11 at 11:48 PM |
I found the Savage switches much too bright at night so I put a variable resistor in series to dim them down - works a treat.
Raz
big_l
| posted on 11/1/11 at 12:31 AM |
Yeah mine are too bright aswell I'll look at putting a resistor in good tip that man !!!!
Check out my blog mnrvortxhayabusa@blogspot.com
dhutch
| posted on 11/1/11 at 08:25 AM |
I dont have savages' but i do have a peice of gaffa tape to put over the blue mainbeam lamp for that reason, with the tape on its just a nice
brightness...
Spray on the screen is the real issue, inside and outside.
Daniel
Bluemoon
| posted on 11/1/11 at 09:34 AM |
Yep it's not that bad in the winter, just be carfull, the main problem is road salt and your right foot..
[Edited on 11/1/11 by Bluemoon]
Dangle_kt
| posted on 11/1/11 at 11:30 AM |
Spray isn't a problem if you don't have a windscreen.
I like the idea of a resistor, wouldn't have a clue how to do it though!
Any numpty advice?
Right foot was only a problem in 1st and 2nd, plus I didn't push on hardly at all.
RazMan
| posted on 11/1/11 at 11:40 AM |
You can put practically any small variable resistor in series with the power feed to the LEDs on the switches. I think I used a 2K Ohm version on mine
(5 years ago now) Connect one side to the +ve feed and the wiper to the LEDs and you can then adjust it to whatever level is right for you.
[Edited on 11-1-11 by RazMan]
Raz
