liam.mccaffrey
posted on 1/3/11 at 10:19 AM |
Engine Mount Plate thickness
Is 1/8" too thin for the landing plates on engine mounts? I'm thinking yes? What have others used?
Build Blog
Build Photo Album
owelly
posted on 1/3/11 at 10:27 AM |
That's about 3.2mm. That seems fine to me but that depends on how big the plate is!
http://www.ppcmag.co.uk
flak monkey
posted on 1/3/11 at 10:40 AM |
I used 6mm plate at the engine and 3mm plate at the rubber mounts with 3mm wall thickness tube.
Sera
http://www.motosera.com
deezee
posted on 1/3/11 at 11:28 AM |
I used 5mm steel for my plate.
coyoteboy
posted on 1/3/11 at 11:51 AM |
Depends on too many things surely, engine in question, design of mount, number of mounts.... If you're hanging a V12 engine off one mount 3ft
from the chassis sides...
BillHoll
I have used 1/8 th for the base plate on the chassis as it the same thickness as the westfield engine mounts I am using.
[Edited on 1/3/11 by BillHoll]
FASTdan
posted on 1/3/11 at 11:52 AM |
I used 6mm - bit OTT but depends on the design really.
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
blakep82
posted on 1/3/11 at 01:03 PM |
3mm is a bit bedy for my liking. mine are 5 or 6mm
________________________
Bluemoon
posted on 1/3/11 at 01:09 PM |
6mm, but it's all fabricated from flat plate in mine (probably OTT).. It depends on the configuration..
