omega0684
posted on 12/4/11 at 07:14 PM |
Been out for my first blat
Evening all,
Just been out for my first blat of the year and i have got to say, SHE.....IS........AWESOME!!!!!!!
Had a miner scare when i realised my front offside wheel was loose but once tightened i didn't half give it some beans and she took
everything i could through at her!
Suspension needs setting up but i still have my protechs to put on and front anti-roll bar to be fitted but for a first shake down run, i was very
happy. A great feeling to have that great big smile back on my face!
Nut and bolt check tomorrow and i need to set up the digi-dash properly, then its just cosmetic finishers!
cheers
Alex
daniel mason
posted on 12/4/11 at 07:22 PM |
what sort of power is the pinto putting out now?
LBMEFM
posted on 12/4/11 at 07:24 PM |
Good for you, summers on the way, I hope to have my first run out next Monday. Lets hope the weather stays bright and sunny.
blakep82
posted on 12/4/11 at 07:28 PM |
awesome can't wait to get a shot of mine. just need the time and money, both at the same time
thats why i end up posting on here so much, all the time in the world, no money
________________________
omega0684
posted on 12/4/11 at 07:36 PM |
195bhp (at the fly), 170lb/ft of torque
daniel mason
posted on 12/4/11 at 07:39 PM |
no wonder she can shift!
omega0684
posted on 12/4/11 at 07:43 PM |
indeed!
daniel mason
posted on 12/4/11 at 07:47 PM |
sorry for the hijack but what width rear tyres do you run and is traction ok. my f20c install should be started this week and drive shafts next week.
i have 205/60/13 a048's all round
omega0684
posted on 12/4/11 at 07:52 PM |
thats ok mate, im running 195/50/15's on mine with Proxy T1R's at about 18-20 psi, but have just secured some OZ Superleggeras with
a048's on same size 195/50/15's (haven't picked them up yet)
there is only only problem with traction and thats when i drop the clutch on full throttle!
[Edited on 12/4/11 by omega0684]
mad-butcher
posted on 12/4/11 at 07:59 PM |
made up for you, hope your still buzzin
tony
Stuart_B
posted on 12/4/11 at 08:01 PM |
very nice, i hope to get my running again soon,
so with that sort of power what spec is that?
stu
omega0684
posted on 12/4/11 at 08:13 PM |
don't make me write it all out please....................
race spec head, 46.1mm inlet, 38.1 outlet, piper r8 cam, kent long pad followers, double valve sprints, kent slim stem seals, professionally ported
and flowed head. Burton cast alloy manifold ported to match head and bodies (45 Jenvey's) with 90 mm carbon trumpets. Vauxhall XE Injectors
running 93mm bore with forged acrylite pistons, cossie rods all balanced to crank, with 3kg billet ali fly with steal insert, and high torque starter.
Alloy vernier & Jack shaft pulleys, custom billet alli crank, water pump and alternator pulleys. Close ratio Quaife clubman box with 3.62 cossie
LSD and shafts.
Stuart_B
posted on 12/4/11 at 08:15 PM |
LSD and shafts.
wow, that is a very good spec pinto very nice indeed.
stu
daniel mason
posted on 12/4/11 at 08:18 PM |
i bet that cost more than mine! good spec that.
omega0684
posted on 12/4/11 at 08:20 PM |
stu
i just thank my boss for the overtime to pay for it!
Ali block and head next
Daddylonglegs
posted on 12/4/11 at 08:56 PM |
I guess the weight of the 'anchor' is a bit irrelevant now then?
[Edited on 12/4/11 by Daddylonglegs]
omega0684
posted on 12/4/11 at 09:19 PM |
no more mickey taking now!
