Norfolkluegojnr
posted on 6/7/11 at 07:50 AM |
MX-5 clutch change anyone?
Hi Guys,
Just wondered if anyone had done a clutch change on an mk1 MX-5 and could advise on difficulty/problems that you encountered?
My 'bargain' won't be much of one if I have to take it to Mr Clutch!
Is it a home job or do you really need a pit or ramps?
deezee
posted on 6/7/11 at 08:01 AM |
I've googled it for you
http://www.miata.net/garage/clutch2.html
Ninehigh
posted on 6/7/11 at 08:02 AM |
I suppose it's possible with a couple of axle stands, but beware that you're going to remove some heavy bits and if a gearbox drops on any
part of you it's probably going to mean a trip to Mr Hospital. It is (generally) easier than a fwd one as it's all in a nice straight line
BillHoll
posted on 6/7/11 at 08:24 AM |
Did this on my driveway with the car on 4 axle stands when the wife destroyed clutch and diff. Took me about 5 hours including changing the diff. Only
advice is start inside the car first, removing the gear stick.
![](/images//smilies/wink.gif)
Norfolkluegojnr
posted on 6/7/11 at 09:11 AM |
Thanks Deezee, i saw that link, but I can't decide if that makes it seem easier or harder!
Bill - doable at home then? I don't want to start this and not be able to finish it. ![](/images//smilies/bigsmile.gif)
BillHoll
posted on 6/7/11 at 11:02 AM |
Yes no problem with just a basic tool kit ; socket set, ring spanners etc
