ctwv50
posted on 25/5/15 at 06:56 AM |
private reg plate year
I'm not normally a private reg person but as this car I've made is just a bit of fun I thought I might consider getting a private plate
even though a large part of my brain is telling me it's a waste of money but, my friend owns quite a good plate but it's an '04
plate and my car is a SVD P reg. As it's Bank Holiday Monday and DVLA are closed I thought I'd ask on here. My car manufacture date on the
v5 is 2015??
loggyboy
posted on 25/5/15 at 08:24 AM |
If urs was given a p due to age of donor then I believe that will be as new as you can make it. Check notes on v5 for more information on donor or
other dates?
Mistral Motorsport
CosKev3
posted on 25/5/15 at 08:25 AM |
I'm sure its car registration date they use, not manufacture date, so you won't be able to use a 04 plate.
adithorp
posted on 25/5/15 at 08:28 AM |
Any replacement plate has to be the same age as current or older than the one assigned.
Not sure you can do it on an age related at all.
http://jpsc.org.uk/forum/
ReMan
posted on 25/5/15 at 08:39 AM |
But yes you can replace an age related plate"..........
www.plusnine.co.uk
loggyboy
posted on 25/5/15 at 08:45 AM |
It's not the age of the current plate that counts. Just the reg date of car, you can jump between any plate age as long as its older or same age
as the reg date. However on a kit there will be either a note on the v5 or on the dvla system that notfiys them of the donor age.
You can definitely replace an age related.
Mistral Motorsport
ctwv50
posted on 25/5/15 at 08:51 AM |
I see so even though it's first date of reg is 2015 the donor still dictates the plate that can be fitted.
loggyboy
posted on 25/5/15 at 08:55 AM |
Thats my understanding yes.
Mistral Motorsport
loggyboy
posted on 25/5/15 at 08:59 AM |
This bloke found out too late! http://www.pistonheads.com/gassing/topic.asp?h=0&t=384723
Mistral Motorsport
ctwv50
posted on 25/5/15 at 09:06 AM |
Oops!
