andylancaster3000
| posted on 23/1/06 at 11:17 PM |
R1 Exhaust Can
Reading through past threads it seems that the standard R1 can is a popular bike can to fit to CECs aswell as BECs. However I can't find any
real figures for noise level. I'm planning to run one on its own on a standard 4age engine and want to know if i'm likely to pass noise
tests at various motorsport events/trackdays!
What is the OD of the inlet tube and how is it attached to the rest of the exhaust. Slide on or bolt on?
Also are there any other suitable cans for this application, preferably slide on.
Any help would be great,
Andy.
andylancaster3000
| posted on 24/1/06 at 12:46 AM |
oh b******, in wrong section, how do I change it!
smart51
| posted on 24/1/06 at 08:25 AM |
you could delete each of your posts and the put it in the other section.
I had an R1 can and cat fitted to my R1 engine at SVA and it measured 100dBa at 7600 RPM
It has a 50mm (or 2" I didn't measure it) pipe
[Edited on 24-1-2006 by smart51]
Andy W
| posted on 24/1/06 at 04:50 PM |
The o/d of the inlet tube is 60mm, which is welded to can.
Regards Andy
