Author: Subject: Tire pressure
kb58
posted on 16/2/06 at 09:04 PM Reply With Quote
Tire pressure
My first post here in the Driving section, after building my mid-engine Mini. The question is, what tire pressure is "about right"?
The car is 1500lbs, 80" wheelbase, mid-engine, 200hp. Weight distribution is 40/60 toward the rear. Front tires are 175/60-13, the rear 215/50-13.
I've tried 15 and 25psi... maybe 20psi is next. Haven't yet taking the car on track so I won't know what pressure is perfect, but out on the street it's hard to tell. The capability of the car is scary good, there's no safe way around here to find the limits, which is why I'm asking.
[Edited on 2/16/06 by kb58]
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
Mark Allanson
posted on 16/2/06 at 10:15 PM Reply With Quote
With such a bespoke setup, I think the only way to tell is to take it out for a scary howl and then measure the temp every 20mm across the tyre width and adjust the pressure until it is even (scary howls are loads of fun so enjoy!)
russbost
posted on 27/2/06 at 11:12 PM Reply With Quote
My axle weights are around 400kg rear & 250kg front (multiply by 2.2 for lbs) around 270bhp. I run 15psi front on 245/45/18 & 18-20psi rear on 285/40/18 rear seems to behave itself!
NS Dev
posted on 28/2/06 at 01:24 PM Reply With Quote
I would concur entirely with the post above. It depends heavily on tyres used, and particularly on the front of your mini, you want the softest sidewall tyres you can find!
15-16 psi front and 18-20psi rear would be my advice, 1 psi either way on a car of 1500lb will make a surprising difference.
Tyre sizes and profiles sound about right too, certainly wouldn't argue with any of that.
posted on 28/2/06 at 01:33 PM Reply With Quote
I'm using 18psi front and back, but I haven't experimented. Works OK for me.
Just a thought - the original question was about mini tyres, so is what we put in our 7-sized tyres totally relevant? It might be better to ask in a mini forum.
OOPS! Ignore me - I just re-read his post - his tyres are roughly the same as mine!
[Edited on 28/2/06 by David Jenkins]
posted on 2/3/06 at 02:56 PM Reply With Quote
i put 18psi cold into my tyres, and i think it was a little high because with new tyres, the bobbles wore off faster in the middle. Maybe it heated up a lot - i had forgotten my pressure gauge so i couldnt check what it rose to.
Jon Ison
posted on 2/3/06 at 04:23 PM Reply With Quote
I cant imagine other tyres are too different, yoko's advice for there 048's is 21psi when hot, in other words whatever pressure cold brings them up too 21psi when hot.
NS Dev
posted on 3/3/06 at 01:17 PM Reply With Quote
Would be interesting to see what temps give what pressures.
On the grasser the outer rear starts at 18psi and 4 laps on a dry track brings that up to 21-22psi.
My only gauge of temp is that 4 laps brings the outside rear from ambient to "can just touch but not for long!"
