GregMcN
posted on 24/5/06 at 09:31 PM |
Fitting Sierra wheel studs
Does anyone have any good techniques for fitting new Sierra wheel studs - a night with a lump hammer has not been very successful - and it was a waste
of time painting the flanges.
Thanks Greg
posted on 24/5/06 at 09:37 PM |
We have just replaced ours. Knocking them out was easy enough, the tough bit was getting the new ones in. We placed ours in the freezer for 48hrs and
then using a suitable aluminium spacer, tightened a wheel nut onto the stud until it pulled through so the flange was flush on the hub.
Phil
ReMan
See my and others method here
http://www.locostbuilders.co.uk/viewthread.php?tid=43704
liam.mccaffrey
posted on 24/5/06 at 09:54 PM |
i plopped the stud in the hole then pushed them in with a vice and a suitable sockt as a spacer so the stud didn't hit the vice jaws
bit of a thwack with the brass hammer ensure seated and voila
8 studs about 10min job max, this was granada studs into cortina hub though, not sure if its different for sierra
[Edited on 24/5/06 by liam.mccaffrey]
Build Blog
Build Photo Album
big_wasa
posted on 25/5/06 at 05:58 AM |
I use a ball joint spliter. Very light work.
posted on 25/5/06 at 09:06 AM |
how do they differ from mk2 escort rear?
I used wheel to pull them on - that was fine. then tried pressing in with a vice - problem is they didn't go straight so bad I almsot could not
get the wheel on
but when I did, pulled them straight again by doing up the wheel niuts, phew....
