posted on 11/3/07 at 09:20 AM |
Pinto rev limit - how to control?
This might be a daft question, but...
2.0 Pinto, Motorcraft electronic ignition, Weber 32/36 DGV carb.
Does the Motorcraft ignition set-up have a built in rev limit?
If not, what controls the rev limit (or not as may be)?
If there's no control in this standard system, wha's the best way of controlling the limit. I've seen rotor arms which govern the
limit, do these work?
Any help appreciated
Nick
auzziejim
posted on 11/3/07 at 09:26 AM |
ring h+h ignition solutions and ask about their rev limiting rotor arms. iirc they are about £15 and you can specify the rev limit.
cossiebri
posted on 11/3/07 at 09:49 AM |
I used a omex rev limiter (had the one with launch control) really easy to wire up , and easy to set up with whatever limit's you want
Had it hanging round the garage for over a year, e-bayed it a couple of weeks ago sorry
If it doesn't fit MODIFY it!!
Cheers BriF
nitram38
posted on 11/3/07 at 11:18 AM |
I use a microdynamics rev limiter with launch control. Works for me!!!
jos
posted on 11/3/07 at 12:57 PM |
i use my right foot
mookaloid
posted on 11/3/07 at 01:05 PM |
With that carb it'll limit itself
posted on 11/3/07 at 01:46 PM |
The question is though, what limited the revs on this set-up when it was in the donor car?
mark chandler
posted on 11/3/07 at 01:59 PM |
Nothing, it will rev to distruction !
flak monkey
posted on 11/3/07 at 03:56 PM |
You can buy rev limiting rotor arms to fit the bosch dizzy from halfrauds. About £10 IIRC and hard cut at 6200rpm.
Sera
http://www.motosera.com
posted on 11/3/07 at 08:23 PM |
So Ford never bothered liniting the revs in the Sierra?
How come people didn't blow their engines more often?
Jon Ison
posted on 11/3/07 at 08:28 PM |
The rattly noise of protest from under the bonnet made you take your foot of the gas.
Nick, I think I must be getting old, cars never had rev limiters until fairly recently, you never driven one without ? God I'm gerrin old.
mookaloid
posted on 11/3/07 at 09:06 PM |
As I said above, with a small carb like that it will limit itself. It will not flow enough air to over rev the motor
Mark
Stu16v
posted on 11/3/07 at 09:15 PM |
Mark
Agreed. That or the bouncing valves...![](/images//smilies/shocked.gif)
posted on 12/3/07 at 12:41 PM |
I guess I have - old fiesta/golf/escort etc, but never really thought about it. I drove 205 GTIs for so long where the revs were soft limited at
about 6250rpm that that's what I remember. Driven diesels since then which obviously have limited revs and not many of them.
NS Dev
posted on 12/3/07 at 01:10 PM |
my briefly owned 205 gti never used to come off the limiter very often!!!!
mookaloid
quote: I guess I have - old fiesta/golf/escort etc, but never really thought about it. I drove 205 GTIs for so long where the revs were soft limited
at about 6250rpm that that's what I remember. Driven diesels since then which obviously have limited revs and not many of them.
Diesels actually self limit. As there is no advance mechanism like on a petrol where you advance the combustion time for higher revs, the diesel is
limited to combustion when the mixture is compressed and spontaneously combusts under pressure.
Mark
posted on 13/3/07 at 12:48 PM |
Mark & Mark - apologies if I sounded disbelieving above, I had just assumed that Ford (and others) would have limited the revs in some way other
than the "natural" limit of the fuel/ignition systems.
I think I'm going to try a limiting rotor arm at least while the freshly built engine is bedding in a bit.
Nick
Exactamundo! ![](/images//smilies/bigsmile.gif)
DarrenW
posted on 13/3/07 at 02:44 PM |
Ive driven my Pinto for a while now and not felt the need to fit a rev limiter. Modded head, 285 cam and 38DGAS. As mark says it doesnt seem to flow
enough air to need limiting.
DD2 has recorded max revs of approx 6,800. Only done that on the briefest of moments. If i limited it to 6.250 as mentioned on here id feel that i was
limiting the output too much. If i was you id probs drive it around for a while and see what you think first before spending the cash. For runnning it
in just limit it yourself at first (easier said than done in these cars though! )
