jabbahutt
posted on 10/4/07 at 02:40 PM |
battery type?
Afternoon
Geting reading to start up the car for the first time and need to source a battery.
Mk Indy, 2.0 pinto engine with standard starter motor and nippon denso alternator off a Micra. No fancy add ons just lights and usual dash board
bits.
What sort of amp rating should I be looking for when buying a battery? if that's the correct thing to look for. Haven't got much of a clue
when it comes to electrics
Any advice gratefully received.
Nigel![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
Mr Whippy
posted on 10/4/07 at 02:48 PM |
You’ll never get any agreement on here.
Why not go to Halfords and get the same that was used on a 2ltr Sierra ? It all depends on if the engine is high compression or standard and if you
want enough for turning it over a bit in the cold weather.
Personally I'd look at around 40 amp/hrs and the size space you have to put it. Others will be more bothered about weight. Try and get one that
is sealed for life and has a battery condition indicator.
[Edited on 10/4/07 by Mr Whippy]
Macbeast
If you're going for standard lead-acid battery, then I would go for smallest and lightest Halfords do (which are not all that small actually)
35AH (measure of capacity - how much you can store in the battery )is probably the minimum. As long as your engine starts reasonably easily so you
don't have to crank for hours, and as long as you don't have masses of electrical gear that will drain battery when idling or at night
then capacity isn't really an issue.
You will also find a CCA figure (cold cranking amps) quoted - usually 300 - 400 Amps. This is a measure of how fast you can get the current out of the
battery and this might be important if you have 8 cylinder high-compression head.
However, for normal mortals, go for minimum size and weight.
[Edited on 10/4/07 by Macbeast]
Mr Whippy
posted on 10/4/07 at 02:54 PM |
here a link to ford sizes
http://www.tayna.co.uk/catalog/238/0/Car-Battery-by-Vehicle-Ford-page1.html
RazMan
posted on 10/4/07 at 04:04 PM |
Or for the smaller, lighter applications ....
Link
or my favorite
Link
Raz
posted on 10/4/07 at 04:25 PM |
Get the one the battery tray (assuming it's an MK one) was designed for. This one is a 069 type...
auzziejim
posted on 10/4/07 at 05:45 PM |
i got one from a fiesta diesel i think it was 9" across and 71AH turns over damn easy and always has a strong spark ![](/images//smilies/bigsmile.gif)
DRC INDY 7
posted on 10/4/07 at 06:15 PM |
I have just got the battery for the sierra it fits into the moulded battery tray as supplied by mk its 43ah 300amps type 085 banner battery from
leisureways in rotherham
[Edited on 4/10/2007 by DRC INDY 7]
Puddle Dodgers Club
posted on 12/4/07 at 07:45 AM |
how much are you willing to spend?
people have use a lawn mower or even large motor bike batteries .
or agel battery - see my post about the odyssey off a man on ebay.
