jos
| posted on 21/4/07 at 05:40 PM |
Clutchless gear changes
Has anybody else mastered the art of clutchless gear changes
in a pinto????
I have - LOL
| posted on 21/4/07 at 05:41 PM |
i spent 3 months in an LDV with no clutch cable
tks
| posted on 21/4/07 at 05:52 PM |
How do you do that when you need to stop!(Red light??))
| posted on 21/4/07 at 05:53 PM |
My mate did it regularly... apparently the gearbox doesn't last long.
smart51
| posted on 21/4/07 at 06:14 PM |
A company I used to work for had a fleet of diesel metrosm as pool cars. All with close to 100,000 miles on them. To speed up their replacement,
several people practiced cluchless shifts on them.
Cluchless upshifts were fairly easy. Rev the engine a bit in the lower gear, pull it into neutral, listen for the engine to drop towards the speed
needed for the new gear and let the syncro do the work. Upshifts were more tricky, needing you to pull the lever into neutral and give a heafty prod
of the throttle to get the revs higher than you needed for the lower gear. The syncro would then let the low gear engage as the engine slowed to the
right speed.
indykid
| posted on 21/4/07 at 06:30 PM |
pull it into nuetral, stop, turn off the engine, put it back into first, then crank the engine til you're moving again.
it only needs a few turns to get momentum back up again.
i drove my cav with a snapped clutch cable for a couple of days last year. not really a big deal, you just have to be a bit more concious of
what's going on 10 cars ahead.
bay parking's not much fun though
tom
| posted on 21/4/07 at 06:34 PM |
Approaching lights balance throttle and pull into neutral. Turn engine off, select first, restart and drive off! This doesnt work on hills, so you
need to plan in advance. In fact, its amazing how rarely you need to stop if you try!
Doing it for so long you get very familiar with the engine noise, so you can pick the revs very precisely and save wear. You can even left foot brake!
stevec
| posted on 21/4/07 at 06:40 PM |
When I picked my Indy kit up the guys in unit next door were just going out in their Transit that they had been driving for ages with no clutch
cable.
Steve.
nitram38
| posted on 21/4/07 at 06:44 PM |
It will be easy.......I have bought a trickshifter
jos
| posted on 21/4/07 at 07:29 PM |
easier on a bec than a cec
blakep82
| posted on 21/4/07 at 08:41 PM |
i used to do it all the time in my cortina, not because the clutch didn't work, but because my gearbox was knackered, and the car was ready for
the scrapper anyway. just got lazy really
________________________
tks
| posted on 21/4/07 at 11:16 PM |
Easyer on a bec as on a cec?
Don't think sow..
to find neutral you need to plan to shift down all the gears...
also how can you downshift a bec gearbox without clutch...
i'm able to build clutchless upshift meganisms wich cuts out the injection during half a second erso... but thinking about it it already scares
me...
Tks
greggors84
| posted on 22/4/07 at 05:52 PM |
In my (maybe limited) experience of doing it I have found its alot slower to clutchless shift a syncro box than using the clutch and heel and toeing
on downshift to set the revs.
Dog box is easier and if well practiced its quicker including left foot braking and clutchless downshifts.
Chris
The Magnificent 7!
Simon
| posted on 22/4/07 at 07:22 PM |
Don't think so.
me...
Tks
With all my bikes, I rarely used the clutch other than for pulling away/finding neutral for either up or down changes. With my old BMW K100 I had to
use the aformentioned method of moving off on starter after cable snapped 35 miles from home.
One set of lights was interesting when I couldn't get neutral and had to stall bike on brakes. Back brake didn't work and front wheel kept
skipping. Ended up using kill switch
Simon
