graememk
| posted on 1/5/07 at 12:18 PM |
Indy Brakes
my Indy that is now on the road has all new brakes on it from pads disks and calipers, when cold they all turn freely but when warm they bind a little
the wheels still turn but they are a little stiff, and you can feel it when slowing down, what do you think? let them wair down take them out and take
some material off ? ideas please.
[Edited on 1/5/07 by graememk]
Agriv8
| posted on 1/5/07 at 12:35 PM |
gut feeling wear them down.
a good blat should sort them out and the sun is out for it.
my Boss has just said I can finish early ( flexi time ) and get some miles in.
regards
agriv8
| posted on 1/5/07 at 12:38 PM |
We had a similar problem when our rears were new - the pistons were not going into the caliper enough (at first) the disc's got hot quickly
until the pad material had been removed... personally rather than remove pad material, I'd let them bind a bit longer as they will be bedded in.
Otherwise you'll be removing material, then bedding them in more...
graememk
| posted on 1/5/07 at 12:40 PM |
thats what i was going to do, but i wanted other peoples views first
many thanks
snoopy
| posted on 1/5/07 at 05:58 PM |
it is most likley to be the break pedal itsef make sure the bolt that goes through the bottom is slack but on the nylock if its tight when it gets
used and warm the bush swells and the pedal sticks on and so do the brakes a common fault easily sorted
[Edited on 1/5/07 by snoopy]
| posted on 1/5/07 at 07:02 PM |
Could be the master cylinder push rod has no slack. To check just crack open a bleed nipple when the brakes are binding, if that releases the brake
the master cylinder is holding pressure .
