graememk
| posted on 19/5/07 at 06:54 PM |
1st break down today
not bad i've covered 900miles since my sva, on the way to spalding tonight there was a big cloud of steam from the bonnet. nothing to bad just a
hose come off, bit of a bugger though as i lost my water wetter.
luck i had some water and tools with me, just didnt get time to use the £10 worth of juice i had just put in
speedyxjs
| posted on 19/5/07 at 07:59 PM |
Bad luck but at least its nothing serious
ASH3
| posted on 19/5/07 at 08:13 PM |
Only your first!!
He He get used to it...
but it just gets better and better
Dont call me out though
graememk
| posted on 19/5/07 at 08:26 PM |
quote: Originally posted by ASH3
Only your first!!
dont call you out ??? but your the head of the MK owners club, your number one voice dial on my phone
whitestu
| posted on 19/5/07 at 09:33 PM |
That's the only thing that has caused me a problems so far - i.e. a hose coming off.
I used some domestic high temp plastic water pipe in my cooling system. Not sure if it went a bit soft or was too short [I'm still talking about
my cooling system].
The longer piece I replaced it with has been OK so far.
I'm thinking I should replace with some Ali pipe.
What do you think?
Stu
caber
| posted on 19/5/07 at 11:58 PM |
At least copper plumbing pipe! plastic is temperature rated for liquid running through it not radiant heat from exhausts or contact heat from touching
or being fixed to hot bits! I f you like the copper look polish it if not spray black, no one need ever know it isn't expensive ally pipe that
has been powder coated
Caber
RazMan
| posted on 20/5/07 at 12:53 AM |
In 3500 miles since SVA I have run out of petrol ....... and I never want to do THAT again
Raz
| posted on 20/5/07 at 07:23 AM |
Broke down on the way to SVA , carb had iced up but then so had I. No problems with carb since
