Author: Subject: Fuel consumption compared to respective donors
Mark Allanson
posted on 26/8/03 at 08:48 PM Reply With Quote
I am designing my fuel tank, and working out range. What I would like to know is how does the fuel consumption comare between a locost and the donor from which the engine and running gear derived.
For example, my 2.0i Sierra donor is reputed to do 28mpg, how will my creation fare? I need to do trips to Bristol (210 miles) fairly regularly and want to do it on one tank. I don't care if it only does 10mpg back lane bashing, but has anyone got any comparasons when touring?
Stu16v
posted on 26/8/03 at 11:33 PM Reply With Quote
My 16v Vauxhall powered car will do approx 25ish to the gallon with steady motorway use.
And is 'kin terrible around the lanes (fuel wise-but who cares.... )
locoboy
posted on 27/8/03 at 02:20 PM Reply With Quote
My 2L pinto averages about 22 on the mix of driving i do in it, i live in the sticks so to get to a main road i need to bash some lanes!
On my drive to and from Stoneleigh this year i got 27.5mpg that was mostly motorway, i was only going a max of 70 as a friend was taking his recently aquired 3 wheeler for its debut show and was following me towing a trailer! My car is in standard tune and is in need of a rolling road session so i may see a slight increase in that figure once everything is set up properly
Colin
Locoboy
Mark Allanson
posted on 29/8/03 at 04:45 PM Reply With Quote
I thought the consumption would have been lighter considering the weight difference - looks like I need a bigger tank!
steve m
posted on 29/8/03 at 10:11 PM Reply With Quote
I do not know what an escort with a 1700 xflow with twin 40 on would do to the gallon
but in my locost its about 15-20 mpg
and i can empty the5 gallon tank in one hour no problem
on the good side, you should hear the noise of four fuel taps sucking air at 6000 rpm
CairB
posted on 30/8/03 at 07:18 AM Reply With Quote
Mark,
My 2.0i pintoed Indy averaged 28mpg for the first 1000 miles. That was with the modified EFI that we've discussed previously and probably a fairly typical mix of thrash / cruise driving.
Colin
Mark Allanson
posted on 30/8/03 at 11:20 AM Reply With Quote
Colin,
It seems that a locost will do about the same as a donor, I think mainly to the temptation to USE WHAT YOU GOT!
Mark
theconrodkid
posted on 19/9/03 at 03:57 PM Reply With Quote
on my recent trip to donny i got about 40mpg A roads all the way,but as chrisw says i never go above 60
who cares who wins
pass the pork pies
Kitlooney1000
posted on 3/2/04 at 10:07 PM Reply With Quote
what everyone is trying to say is, it depends on how the weld spletter, fibreglass, filler and oil has added to the weight of your right foot
