New Topic New Reply
Author: Subject: What size bushes for panhard rod and where best to get them
donut
posted on 10/10/07 at 07:31 PM Reply With Quote
What size bushes for panhard rod and where best to get them?
Many thanks
Avoneer
posted on 10/10/07 at 08:42 PM Reply With Quote
Depends how big your orifice and bolt hole is.
Pat...
Volvorsport
posted on 10/10/07 at 09:39 PM Reply With Quote
rose joints - adjustability !.
www.dbsmotorsport.co.uk
getting dirty under a bus
James
posted on 10/10/07 at 11:59 PM Reply With Quote
Pat...
What he said!
donut
posted on 11/10/07 at 05:58 AM Reply With Quote
Ok where from?
bpgoa
posted on 11/10/07 at 09:54 PM Reply With Quote
I'm with Volvosport - even if Volvos are wrong..
I created two spigots on the lathe tapped one left handed and the other right handed that way you don't have to unbolt an end to adjust it and the control is finer (not that it would make that much of a difference)
when the spigots were pressed into the ends of the tube, I drilled a hole through the tube and into the spigot... then filled it full of weld... for safety...
Any help?
oh yeah ... ebay for rose joints... i used 12mm because i had the taps, but 1/2 inch are a lot cheaper
if you don't have access to a lathe then bring gifts of beer and I'll help you out..
[Edited on 11/10/07 by bpgoa]
On and On the River flows... We the Undertow
Avoneer
posted on 12/10/07 at 08:35 AM Reply With Quote
So your spigots ae only held in by a small blob of weld?
I'd feel better with them fully welded all the way round where they enter the tube.
Pat...
bpgoa
posted on 12/10/07 at 11:26 PM Reply With Quote
no... welded all around... then had the hoil fill for security....
New Topic New Reply
