CRAIGR
posted on 26/2/08 at 06:03 PM |
R1 5pw clock /headlight wiring
Anyone know if i can use an import headlight /clock loom and clocks on a uk main loom without grief.
Also I assume a speedo healer will change clocks from kph to mph and then allow me to calibrate them.
[Edited on 26/2/08 by CRAIGR]
jimgiblett
posted on 27/2/08 at 12:21 PM |
It shouldnt be a problem if both units are 5PW.
If the clocks are Euro spec then the speedo healer can change the reading but it it will still say kms. To get this changed and reset the clocks to
zero you'll need to send to someone like Scorpio Electronics who will relieve you of £60. The dash will then be UK spec and swap kmh to mph at
the press of a button.
- Jim
GregMcN
posted on 27/2/08 at 08:56 PM |
Euro 5PW clocks
I ended up with a set of Euro 5PW clocks but did not realise when I bought of ebay.
No problem correcting them with a speedo healer and I just put a small piece of black tape over the 'k' so they read m/h which was OK for
SVA
Greg
