whats the MOT rules please?
i have washers, but do the wipers need to go when you press for water ?
how many speeds does it need?
does it need to have intermittent wipe ?
will the MOT guys want to see a demister ?
thank you
graeme
[Edited on 15/11/08 by graememk]
Wipers need to wipe. They need to cover a certain swept area and be in good condition. No restrictions on speeds or self park. The squirters need to
squirt a usable spray within the swept area. No restriction as to when they can be squirted or if the wipers need to be operating.
Demisters not an MOT item.
HTH
[Edited on 15/11/08 by owelly]
Wipers can work on separate switch
Only needs to have 45 cycles or more per minute
Dont need intermittent
Not sure about demister
No demister, Washers just need to squirt with no wipe needed. Wipers just need to wipe.
AS owelly said
As above but pretty sure they have to self park.
adrian
herrm got to make them self park and one speed then
result
Self park is not part of the MOT. You could have manually operated ones if you like!!
