Hi, I may be having stupid ideas here but wondered if:
is it possible to remove the Brake master cylinder/servo/vacuum hose from an old Fiesta CVH and replace with a nice new aftermarket small cylinder and
just run new pipes to all corners. Thereby removing the old system apart from the brakes?
Would i just blank off the engine end of the servo hose?
I know its an old kak 1986 car and not worth the hassle but if possible, it might be getting me thinking of making it a centre seated driving position
with new pedal box and just altering the route of the accelerator cable and steering linkage.
Doing this is cheaper than buying a shell and starting again and i like the front wheel drive.
Actually, going a step further is making me also ponder the idea of saving more weight on the front end with making a frame for front wishbones
etc.
Your really want to downgrade a "Mission Critical" safety system?
I recon it will feel like you have no brakes at all however hard you press the pedal, unless you make some other changes to compensate.
Also your insurance company will not like it one bit. Assuming this is a road going car.
It's on an auto grass car with sod all weight.
The aftermarket brakes are better than manufacturers ones I guess or we'd never be allowed them on kit cars and 4x4s
the back is all cut out, no floor and the axle has gone also
only drums and a frame remain
in essence folks its just a frame with a body just like our kits
