Have a oe pinto engine running a 32/36 weber at the mo, this is soon to swapped for a 2.1,gas flowed big valve head and fr32 cam with bike carbs. will
the original mechanical pump run this ,or am i better off with an electric pump.
I know i need a pressure regulator ..do i need a return to the fuel tank as well.
any info appreciated.
Hi,
Buy a motorbike fuel pump fit and forget.
No need for a regulator then or a return.
Hi
I went through this on my pinto (2.1L, Dave Walker head, REC Race Valves, 44.5mm inlet, 38mm exhaust, Piper A8 cam) which was fitted with a pair of
45mm twin-choke dellorto carbs.
You definitely need an electric fuel pump (the mechanical one won't be rated to the amount of fuel you can drink at full chat) and you need a
pressure regulator (electric one may over-fuel your carbs). They're not expensive.
You don't need a return run - the all the fuel the pump delivers is consumed at the carbs, and the regulator means the pump doesn't supply
too much fuel to carbs that has no-where to go.
I hope this helps.
If you haven't started building yet, my pinto setup is coming up for sale - the head alone would cost over £600 now, the carbs regularly go for
more than £300 on ebay, and the whole lot has been set up and maintained by Bogg Brothers ("it's a right powerful lump is that"
Getting the engine as a set with the carbs alone would save you £100 on the rollers - it's specifically jetted for this engine. If you're
interested, it comes as a full engine including:
most bike carb's don't like running with high pressure fuel being forced into them...
a pump from a bike running carbs are the simplest / cheapest way to sort this as they regulate the fuel pressure themselves
any carb's bike with similar power should have a pump you could use - but it can't be from a fuel injected bike as they run at much higher
pressure.
I got a ZX9R one for mine, some of these are quite neat external pumps on a little mounting bracket with a fuel filter and shouldn't cost more
than £30 - £40 from a breaker / ebay / etc...
(my one is like this one: eBay Item only I didn't pay that much for it)
[Edited on 10/8/2012 by mcerd1]
+1
Hi, as has been said the bike pump is the cheapest, easiest and most reliable. We have a stock and can supply you a pump if needed. :-)
Originally posted by Garyd
Hi,
