MK4 Golf Subframe Captive Nut
SeanStone - 8/10/12 at 08:06 AM
When replacing the wishbones on my MK4 golf, the front most captive nut for the bolt that goes through the bush has come loose/un tacked
I've been advised that this will require a new subframe, however, is it possible to re-weld this on?
Peteff - 8/10/12 at 08:15 AM
If you can get at it you should be able to weld it. You can make a plate with a nut welded to it and weld it in place if you can make a hole for it to go in.
