Changed mind about a digi dash and stuffed some clocks in
Clocks You Tube Link...here
Bottom set are flashing because they have a
high & low warning setting & not getting
any signal..
[Edited on 20/2/13 by johnemms]
They look really
I figured with most cars higher & looking into my car..
Give them somthing to look at!!
I got my rev change lights - so all good !
Looks awesome. I'd have some of that, if I weren't scared of the price tag... One day...
SPEEDO 99.99
TACH 82.99
FUEL 49.99
WATER 52.99
OIL TEMP 52.99
TOTAL : £338.95
Would you accept £260 ?
Again I look forward to your reply ..
John Emms
Hello,
The lowest Offer we would be able to accept would be 290GBP.
Thank you
Paid 290+30 duty Very well boxed - loads of fittings too..
Type 9 electronic speedo output off ebay £13
Fuel sender on mine is 10 - 70 ohm
A bit plasticky but 'fun' ..
was going to pay 250 for a digital dash..
To: customerservice@glowshiftgauges.com
Sent: Sunday, January 27, 2013 7:17 AM
Subject: RE: Ebay - Best offers
I would like to put together a dashboard with the usual items:
SPEEDO 95MM 10 COLOUR SPEEDOMETER MPH GAUGE W. TRIP METER | eBay
TACHO (0-8000 ?) 95MM 10 COLOUR IN DASH TACHOMETER GAUGE W. PEAK RECALL | eBay
FUEL 52MM ELITE 10 COLOUR FUEL LEVEL GAUGE 73 - 10 OHMS | eBay
WATER 52mm 10 COLOUR STEPPER MOTOR WATER TEMP GAUGE w WARNING | eBay
OIL TEMP 52mm 10 COLOR STEPPER MOTOR OIL TEMPERATURE GAUGE | eBay
What actually happens when it gets to the programmable warning point? It would be good if you could set the rev limiter to green under 3,000, blue up to 6,000 then orange and red for the shift warnings.
I must admit if i was building from scratch i would use the donor clocks and carefully disguise with circular masking to control costs.
