pc3 ignition problem questionsjlayton - 4/7/15 at 06:51 PM
Hi as above with a pc3 usb do you need the ignition module and multi hub with boost input harness and sensor, To run a bec turbo safely. As I have
bought both but just read the boost input on the multi hub can adjust the ignition timing
