can any one assist in turning me up a mild steel sleeve in exchange for beer tokens?
wants to be 100mm long with a 17mm hole through middle up to half way (50mm deep) and 15mm dia hole other end approximately 23-25mm outer diameter,
what ever is easier with stock.
can sketch if the attach doesn't make sense
thanks in advance
[img][/img]
[Edited on 3/8/18 by will121]
I can do that for you but not for a week. Have you any tolerances on the bores?
