Hi All,
Keep promising that I'll take the Fury out for a blast in between the floods but never quite happens. I'm just after any advice for what one
should do over the winter, given that the car may not see the light of day until spring. Its a silvertop Zetec and type 9 box so nothing special and
low maintenance.
I never used to bother doing anything with my old triumphs, TVRs and Land rovers and were all OK as long as I kept the cetec trickle charger going.
This may have been more luck than judgement !!
All comments welcome
Jeremy
I drive my kit all year round, so I just leave the battery disconnected when going away on a work trips for a month at a time.
You could drain off the fuel, but I wouldn't bother if it's just for 4-5 months.
I just keep the battery charged on mine. Only problem I've had was the fuel filter getting gummed up. Carbs were ok though.
