I am looking at a long journey without a spare and wonder what tyre gunk/weld people might recommend or suggest I avoid?
Howard
IMO they're all as good/bad as each other. They'll get you out of the poo most times and cover you in sticky poo the rest.
If the cause (nail/screw/etc) has come out they tend not to work, so best to have a repair string type kit as well.
Thanks Adi.
Much appreciated advice.
I shall have a look today
My kit seems to be too light to flatten its tyres!
My vote goes to Slime. It's a preventive, as in you put in when your tyres are puncture free and forget it, any punctures you do get are instantly sealed.
In my experience they're much of a muchnes really. Most will get you out of trouble and off the side of the road.
Once used in a tyre, the puncture can't be repaired by a tyre fitter. I believe the tyre fitter has to bin the tyre and sell you a new one.
That said, calling a tyre fitter out to you at the side of the road can be £££ too + a long wait.
Originally posted by nick205 ...Once used in a tyre, the puncture can't be repaired by a tyre fitter. I believe the tyre fitter has to bin the tyre and sell you a new one...
I have an old Dunlop Reddiplug kit, but with the modern repair strings. I have repaied loads of tyres with it, the only failure was a 10mm bolt that
had gone through the tyre, bit too big a hole. New versions are available, but the one I bought was rubbish, so I got the old Dunlop kit.
I also carry an aerosol tyre repair, and my kids have a couple in their cars. I have been emphatic that if they get a puncture in a dangerous place to
use the foam to inflate it so they can get to safety.
I have had lots of recommendations for "stop n go" on another forum - yes I know that is cheating but it seems well respected in the USA - any thoughts on that over here?
Not quite true. You can repair them but you have to wash out all the fluid first (very messy) leave the tyre to dry (time consuming) and make a very good job of cleaning the surface prior to patching. Would I do it for my own or a mates tyre; yes. Would I do it for a random; probably not.
[Edited on 12-6-2023 by adithorp]
