I'm considering going for a fully flat floor on my Fury.
If I understand correctly the main benefits are reduced drag and reduced lift.
At the moment only the seat areas are panelled so all under the engine, transmission tunnel and diff & petrol tank etc are exposed.
What thickness of ally sheet should I use - won't be standing on it like the main floor and I don't want to add too much weight.
Also I guess it would be useful if its removeable so are rivnuts the best bet (M5?)
The sump is still going to stick out so dropping the oil won't be any more diffcult but oil filter access could be.
Any tips appreciated.
Oh and where is the best place to buy sheets of aluminium? I'm in Northampton.
Try:
ASC Metals,
Crow Lane,
Billing
http://www.applegate.co.uk/engineering/company/co_1063646.htm
Watch out for engine bay temperatures.... nowhere for the air to get out if its fully paneled.
Chris
Hi yep engine bay temps will need to be checked and vented if problems. Also Diffs can be a problem. On the race cars they will do a 1/2 hour race
just. But if testing for longer periods they overheat. Meaning venting and cold air feed is nesercery.
HTH cheers Matt
I was advised to use 1.6mm by my Lotus friend. Dont want too much weight as you say
I'm planning the same thing. I'm going for 1.6mm and I'll fasten it with 5mm capheads. I'm going to put an NACA duct in the tunnel
section to feed some cool air to the diff', a vent in each side of the bonnet and 2 vents in the indentations on the top of the LeMans bonnet.
adrian
Originally posted by procomp
Hi yep engine bay temps will need to be checked and vented if problems. Also Diffs can be a problem. On the race cars they will do a 1/2 hour race just. But if testing for longer periods they overheat. Meaning venting and cold air feed is nesercery.
HTH cheers Matt
