Cleaning up brake fluid
ditchlewis - 12/7/08 at 06:22 PM
Well i spent the afternoon in the garage and got most of the tasks done.
the brake cylinder needs replacing after it dumped the fluid in the foot well. what is the best way to clean the fluid up.
it has already stripped off all the paint on the floor and the powder coating on the chassis. i want to paint it soon and i want to make sure the area is truely clean.
ditch
jonesier1 - 12/7/08 at 07:20 PM
water..if we spill any on cars at work wash down with water.bit difficult in a floor well in know.
rusty nuts - 12/7/08 at 08:38 PM
Brake cleaner works well . Also its a good degreaser for small items, for removing oil and grease from upholstery and is as good as eazistart for starting engines
David Jenkins - 12/7/08 at 08:42 PM
Just make sure you're in open air when you use it!
ditchlewis - 12/7/08 at 09:03 PM
many thanks lads. i will try these ideas out. just want to make sure the paint sticks.
ditch
