got a full engine including loom clocks everything from bike all i need to know is what do i need to get the speedo accurate do i need to run a retuen
fuel to the tank and most important do i need to dry sump or swivel pick up the engine to protect it . most of the work will be track days and slow
runs out with missus all suggestions greatly received
cheers rob
was the blade carbs or injection? If carbs then return fuel line will be needed.
You will need a new engine cradle.
If I had a busa I'd dry sump it, but thats cos they cost a fortune, and for mainly track work it will be in for a lot of fast corners which
equates to possible oil starvation. A worthwhile investment.
You need a speedo healer to get the clocks to register the correct speed.
[Edited on 11/10/08 by Dangle_kt]
on top of above,
Also new exhaust manifold,
Possible power comander easier for mapping,
TRT which tricks the car to get full power,
Sump you can dry sump, others like westfield do a modified wet sump,
etc im sure someone else will put 2pence in
You may not need a return. Some of the more modern bikes controle the presure by the ecu..
Originally posted by INDY BIRD
on top of above,
cheers for replies different bonnet i hope not running to a very tight budget on this one what about the shocks i would have thought the blade and
busa engines would be very similar in weight. and i thought this was going to be a simple engine swap stripped the car yesterday having full cage fit
as well so there is not much left now stood back and thought what have i done then thought how good it will be when finished again.
