I’m just going through my final jobs list on the car and the front brake hose end is not IVA compliant, I know it needs to be a permanent solution so
I’m guessing a bit of silicone hose and some cable ties is not acceptable. Any suggestions on an appropriate way to protect it?
Daf
Assuming you mean brake line fittings, then mine were not covered and passed. The test is for a sphere to contact from the front and my tester said
they can't waggle it around in there! I had powerlites too.
He did say something about the Sierra uprights and the mushrooms needing to be held in by something more than the pinch bolt though. Westfield Sierra
sdv has a plate through the pinch bolt, so was fine.
oh, and make sure your brake lines don't touch the wishbones while turning lock to lock. I "pigtailed" mine.
[Edited on 12/7/15 by kingster996]
Originally posted by kingster996
Assuming you mean brake line fittings, then mine were not covered and passed. The test is for a sphere to contact from the front and my tester said they can't waggle it around in there! I had powerlites too.
He did say something about the Sierra uprights and the mushrooms needing to be held in by something more than the pinch bolt though. Westfield Sierra sdv has a plate through the pinch bolt, so was fine.
By pigtail I mean twisted to form a single spiral, so the hose can spring in and out, but not so much that it kinks.
Mine weren't tested at IVA either nor were they covered
Thanks guys, they're not covered and the job is ticked off my list!
I will be complaining if I fail on it though
Are those hoses made with compression fittings?
As above, I don't think he'll get the sphere in there. You can buy large polystyrene spheres in virtually identical sizes for a quid or two if you want to check yourself, or just make a cardboard cut out of the radius, but I wouldn't worry about it.
They are yes, I've got the paperwork to go with them though to show that they have the insert into the hose.
I got them from demon tweeks - I have the part number on the recept and a matching part number in their catalogue with diagram and description. I'm hoping this will be okay for mr IVA man - I'll let you know!
