Does anyone know the dimensions of the maxi lower ball joint? I'm looking for the taper, the size of the smaller diameter at the top of the hole in the spindle, the diameter at the lower large hole, the thickness of spindle that the ball joint taper fits into, the thread size, and lastly the distance from any point to the center of the ball pivot point. I've searched he archives and can't seem to find all of this. I'm sure someone who has done a bot of suspension design must know these dimensions.
I may be mistaken but I was under the impression that the two were interchangable. So the cortina spindle dimensions would be great thanks
I may be mistaken but I was under the impression that the two were interchangable. So the cortina spindle dimensions would be great thanks![]()
Thanks Rorty,
I'll send you a u2u with my email address.
CJ
Rorty, I too would be interested in the dimensions so if you could u2u me the information I would be grateful
