Sadly I’m selling my C20XE package off in parts. I had a bolt loosen up in my air box and get sucked in on start up following lunch on my second
track day after I had it rebuilt by Steve Milton and upgraded to a dry sump kit. Sadly it has ruined the head and damaged a piston, pushing me to the
decision to go turbo route as my next project.
These are the individual items for sale:
Caterham Carbon Air Filter Cover – designed to reduce induction noise. £250 SOLD
http://caterhamparts.co.uk/product.php?id_product=2812
Caterham R500 H Box 6 speed and spacer (so you can use a standard type 9 bellhousing) – In Perfect working order £1200 Provisonally SOLD
SBD type c Vauxhall XE Manifold – renown to be one of the best manifolds ever made to release power and no longer in production. £500
Custom Wunoff repackable exhaust silencer and straps have only been used on 5 track days. £250 or complete package with Manifold and I will through
in a gasket. £700
MBE 9A4 ECU and custom loom from SBD purchased on 05/06/15 so still under warranty. £750
TTV lightweight flywheel like new has done less than 200 miles/2trackdays £125 Provisonally SOLD
Uprated clutch Gp1AP plate (200 bhp, high friction material and stronger hub springs) has done 2 track days so still looks like new. £75 Provisonally
SOLD
SBD 220 Vauxhall 20xe Camshaft (requires pocket pistons) I’ve been very impressed with these. I had them dialled in early with more torque in mind.
Made just over 200BHP and 175Ftlb of Torque at Track and Road. £175
Set off Williams C20XE forged conrods with ARP 2000 Bolts. £125 Provisonally SOLD
ARP head bolt kit, 2 track days old, therefore like new. £80 Provisonally SOLD
ARP main cap bolt kit, 2 track days old, therefore like new. £75 Provisonally SOLD
ARP flywheel bolts. 2 track days old, therefore like new £30 Provisonally SOLD
Pair of Turbo Sport Vernier pulleys 2 track days old, therefore like new. £100
Set of complete double valve springs. £50 Provisonally SOLD
C20xe to type 9 bellhousing. £100
Type 9 Gear lever extension and quick shift gear lever. £50 Provisonally SOLD
Set of Mototron/Siemens 690 Injectors + One spare. £150 Provisonally SOLD
Complete Type 9 Slave cylinder (Inc Mount, Bearing and 2 different types of spacers.) £100 SOLD
Complete Dry Sump kit £1750
Pace Dry sump same as SBD low line kit as they make them for SBD
Front Cover
Mocal Remote oil filter housing
Custom Made hoses which have press fittings
5” SBD Cleanable Tank
External trigger wheel with alternator, round tooth cambelt pulley and SBD sensor. Sensor is made for the connection on the sump.
Rocker cover which has been capped. Will be repainted before shipped.
And engine block blanking kit.
This complete kit cost well over £2500 and is ready to fit, as long as its fitted on the exhaust side and the tank connects to passengers footwell,
the hoses should fit. Again have only been used for 2 track days.
[Edited on 23/2/16 by drummerdrum_uk]
Can I have first refusal on this please, pending further info? Who made these items? Any pics? Thanks
hi, i'll take the airbox please
I may take the manifold too but may i see a pic of it first please and what car was i fitted into?
U2U sent ref exhaust package
2 dips on the airbox please, could you send pictures in case the first one passes on this please. Cheers Volker
Payment sent for airbox Adam
Hi
Very interested in the Cat 6-speed box. Where are you based?
U2U sent
any luck with pics or more details?
Deposit paid
Hi,
Do you still have the Type 9 to XE Bellhousing?
Alan
SORRY ALL ITEMS SOLD
