UK Car Registered 05/11/1997
Mk1 1.8 manual
SORN since November 2014
V5 present
Car wad stored in garage when not in use - Until last month.
carpets and most trim removed
Heater removed
Dash has been stripped
Push button start installed
Soft top and frame removed.
Hardtop has plastic rear screen (could do with tidy)
Seats removed and one Cobra Monaco Pro fitted with Schroth 6 point harness
TR lane rolls bar
Engine has not been modified except for a change on the air filter and Carbon filter removed
Engine chassis brace fitted
New Radiator fitted March 2020
exhaust decat
new rear exhaust box
Brakes/callipers serviced
EBC Yellow stuff pads
stainless Steel braided Brake hoses
Gaz Gold Pro Shocks
Suspension was set up for track by pitstop.
15” Enkei Wheels
Federal RSR tyres
Paint work is in generally ok condition. Slight crease to near sidefront wheel arch ( probably knock out if liner removed)
Rear Off side wing inner sill and outer lower section was replaced earlier this year. Paint works on this wing is dull but fine for a track car.
Need the space so sadly this must go.
2nd set of wheels And torsen 2 centre available separately.
£1000 - no offers at that I’m afraid
Can send photos
Matt 07463768684
